CPC6128 + HxC problems
I just make some tests with my CPC 6128 and an up to date SD HxC.
Every hfe file I made 2 or 3 years ago are still working well into the HxC.
Now I have prepared a dsk file which works into Mame and also on the CPC into a FlashFloppy Gotek.
But the hfe file I made with it (W64 HxCFloppyEmulator v2.14.4.1) did not works into the HxC. Even a Amsdos "CAT" give strange results.
I use the custom "standard 3" Amstrad CPC" disk layout. load the dsk file, I see then "Raw image - 40 track(s) 1 side(s)", and finally export into hfe.
Every hfe made by this way actually did not works...
What am I doing wrong ?
Also get a description of the Amstrad floppy layout I can input by hand instead of the custom layout will help.
Thanks and regards.
Philippe
ps : both files dsk and hfe are here under joined
Thanks and regards.
Philippe
- TE_v1.73_Phil..zip
- (101.35 KiB) Downloaded 2886 times
Re: CPC6128 + HxC problems
I don't/can't provide any support to flashfloppy users...
But :
Amstrad DSK aren't raw files
. This format has multiples headers tracks and sectors descriptors.
So don't use the raw loader for amstrad edsk/dsk files. Just use the "Load" button or drag & drop it to the main window. That's all.
But :
The download of the SD card HxC floppy emulator of the BETA software doesn't work.
I checked over the last weeks, still it doesn't download the BETA completely. Always some part missing.
Please help!
oh... it's this link:
Please help!
I am not sure to understand. What is the problem exactly ?TFM wrote: Wed Apr 05, 2023 2:55 pm The download of the SD card HxC floppy emulator of the BETA software doesn't work.
Please help!
It does work :
Not here sadly. Can you post a working link please?
(Using Chrome and Windows 7).
No. The link is working for sure. The problem is on your side.TFM wrote: Tue Apr 11, 2023 6:17 pm Not here sadly. Can you post a working link please?
(certificate issue on windows 7 ? Antivirus false positive ? bad firewall / router ? outdated browser ?)
Well, I can try another PC, but the rest of the world works here.
Nobody out there how can give the link a try please?
Here, it loads 12,4 of 12,6 MB then an error occurs. Tried it lots of time now.
Me, but it seems that you don't believe me .
