Command line for a batch process.
javidoom
Post by javidoom »
Hello
Is there any chance to create an automatic creation of ms-dos disks from various directories?
I mean... I have several directories, filled with roms for the GameDoctor SF7 (snes copier), and I need to inject them (each directory) to a HFE file.
Example:
c:\snes\game1\anyarchiveinsidedirectory
c:\snes\game2\anyarchiveinsidedirectory
c:\snes\game3\anyarchiveinsidedirectory
etc...
to:
game1.hfe
game2.hfe
game3.hfe
etc...
I would use Excel and a batch process to do that... but only if there is a command line to use. :)
Or is there another way to do that? :)
Re: Command line for a batch process.
javidoom wrote:Hello
Example:
etc...
to:
game1.hfe
game2.hfe
game3.hfe
etc...
which file extension are used with these rom ? if it's *.SMC, this should already works in command line.
javidoom
Post by javidoom »
Hello
This is one of the problems...
The extensions aren't always the same, sometimes there is no extension, sometimes it's .078, and another I've seen .s, .o, etc...
The conversion utility (Ucon64) converts from SMC (super magicon format) to GD3 (game doctor)... Making this odd naming extensions in the filename.
The name format in this case, is always:
SFxxyyyz.???
SF=always is SF
xx=size in mbits of the rom (8,12,16,24,32,...)
yyy=first three character of the name
z=A or B or C, etc... based on number of disks used for this game
???=strange extension... :(
Any idea how to convert them in a batch? And no one by one? (There are +3000 games...)
SFxxyyyz.???
SF=always is SF
Any idea how to convert in a batch? And no one bye one? (There are +3000 games...)
for the moment try to do a batch rename of the files extension to smc.
after this the batch converter will create a fat12 floppy with the file.
javidoom
Post by javidoom »
Hello
Thanks, I'll try that.
I'm still wayting to the unit, so I cannot try it right now...
Thanks again!
