SDCard HxC Floppy Emulator
weyerma
Post by weyerma »
Hello, aren`t the schematics for the sd version still available ? I only found the USB version on your site.
Re: SDCard HxC Floppy Emulator
weyerma wrote:Hello, aren`t the schematics for the sd version still available ? I only found the USB version on your site.
it is available, but the firmware aren't available. (have a look to the download section).
Why do you want it ?
weyerma
Post by weyerma »
i only found this:
> HxCFloppyEmulator software v1.3.14.0
> SD HxCFloppyEmulator firmware upgrade v1.3.0.2
> SDCard HxCFloppyEmulator Manager (for Atari ST and Amstrad CPC)
Documentations:
> User Manual : SDCard_HxC_Floppy_Emulator_User_Manual.pdf
> General specifications : SDCard_HxC_Floppy_Emulator.pdf
Other:
> SD HxC Floppy Emulator mounting kit documentation.
> HxC_Floppy_Emulator_software source code
> HxCFloppyEmulator software release notes
> Prototype SD HxCFloppyEmulator firmware upgrade v0.2.2.0 (archive)
Sorry if i`m to stupid to find it :-)
I like to make a SD-Version with the Display and the LED`s on the front side, to fit better in my Ensoniq Mirage. I also like to use a black contrast display with orange font, to match the original 2 Orange Segment LED`s.
So i think it would be the best way for me, to build it self.
weyerma wrote:i only found this:
Documentations:
Other:
Look at :
But sorry you cannot build it since you don't have the firmware. and this one isn't free.
weyerma
Post by weyerma »
can i not buy just the firmware, or 2 programmed pics(if you scared about copying) from you ?
weyerma wrote:can i not buy just the firmware, or 2 programmed pics(if you scared about copying) from you ?
You can get a kit (pcb + pic) from Lotharek.
Try to contact him.
weyerma
Post by weyerma »
ok, i will try.
Thank you
