Latest HxCFloppyEmulator software v2.5.6.6 fails to run on win10
rjflory
Post by rjflory »
Hi-
Just downloaded https://hxc2001.com/download/floppy_dri ... r_soft.zip
( HxCFloppyEmulator software v2.5.6.6 ) software emulator and attempted to run on a win10 machine directly from the zip archive.
Both of the enclosed .exe progs fail instantly, reporting the enclosed DLL/lib cannot be found.
I noticed the .dll filename in the zip archive are lower-case, but the error dialog seems to be expecting .dll filename with upper-case filenames.
The present/missing .dll filenames differ only in lower/upper case-ness.
Is this something you can duplicate on your side?
ron
Re: Latest HxCFloppyEmulator software v2.5.6.6 fails to run on win10
rjflory wrote: Sun Jan 22, 2023 7:13 pm ... to run [...] directly from the zip archive.
This can't work this way. You need to unpack the whole zip file.
