Kaypro II blank disk image
NorthStar
Post by NorthStar »
Is there a way to create a blank Kaypro II SSDD disk using the HXC Floppy Drive Software?
I have files backed up for my Kaypro on my mac and the goal is to take the files and get them into the .HFE format for my Rev. F HxC Drive Emulator. Other IMG and TDO formatted disc images (CPM 2.2 and the like) all converted and work beautifully.
I tried deleting files on these existing images but cant find a way to move my files to these.
Any help would be greatly appreciated.
Thank you,
Rusty
Re: Kaypro II blank disk image
I can add the blank image to the software : Format an hfe with the kaypro and share it here (or by email : hxc2001 at hxc2001 com). i will generate the xml file and include it into the software.
NorthStar
Post by NorthStar »
Great and thank you. Ive been consistently upgrading the HXC software but I dont see the blank Kaypro II. Im sure im missing it but this is what I get if helpful. I'll try and email as well. I sincerely appreciate it.
Screen Shot 2023-11-30 at 2.20.12 PM.jpg (42.54 KiB) Viewed 74667 times
