Anilam 6000
Agp2205@gmail.com
Anilam 6000
Hi
I have recently started working at a place. They have hxc floppy emulator sd version installed in one of the machines.
Currently no one knows how to use it. I have been trying to get my head around it. But its not working. I will upload some photos for reference. Can u please advice me
How to convert a mastercam cnc program file .nc to a format the hxc can read.
And how to copy the prog to my cnc machine.
Its a quantum make cnc mill with anilam 6000 controller
Re: Anilam 6000
Copy the content of the "HxCFloppyEmulator_DosDiskBrowser" folder present into this archive to the sdcard root folder :
https://hxc2001.com/download/floppy_dri ... rowser.zip
Agp2205@gmail.com
Re: Anilam 6000
Hi Jeff, Thanks for getting back to me.
I am copying the files at the moment.
I will try it and update u
Agp2205@gmail.com
Re: Anilam 6000
ITS STILL NOT WORKING PLS REFER TO THE ATTACEHD FILES
- 20221116_073530.jpg (200.67 KiB) Viewed 47761 times
- 20221115_150037.jpg (175.73 KiB) Viewed 47761 times
- 20221115_145319.jpg (202.96 KiB) Viewed 47761 times
Agp2205@gmail.com
Re: Anilam 6000
More files
- content of the file to read on machine.jpg (149.08 KiB) Viewed 47761 times
- 20221116_073718.jpg (178.79 KiB) Viewed 47761 times
- 20221116_073607.jpg (177.8 KiB) Viewed 47761 times
Agp2205@gmail.com
Re: Anilam 6000
more files
- Machine panel.jpg (192.12 KiB) Viewed 47760 times
- Floppy Emulator File chosen.jpg (131.03 KiB) Viewed 47760 times
- error message.jpg (162.14 KiB) Viewed 47760 times
Agp2205@gmail.com
Re: Anilam 6000
It seems that you are trying to load/find the file from the internal machine harddrive / disk (C:\ C:\USER ? ).
Have you tried to read the floppy disk (A:) ?
Re: Anilam 6000
IHelp! I am currently trying to put a floppy drive emulator on an Anilam 4200T control fitted to a lathe. I don’t know if the Anilam 600 is the same, but the 4200T runs on DOS 6.22 which uses FAT 16. I have one of the latest GOTEK‘s for a usb memory stick, with small LCD screen and encoder fitted for selection of units on the memory stick.
I have an old PC running on native dos 6.22, (meaning the computer actually runs on dos, as opposed to a dos program within windows). This one is to emulate the 4200T, which is on another site, and only accessible with a long drive.
Also have a laptop running on windows 7, which I have been using to run Gotek and flashfloppy software for attempting to format the usb stick.
I cannot get the HxC software to format the memory stick at all, It asks for an FTDI driver which I have downloaded, but windows 7 just tells me there is already an up to date driver installed, and won’t accept it. I suspect that even if it did work, it would format the stick as FAT 32.
I managed to use the ipcas software 1.40i version, which ran well on windows 7, and formatted 100 disc images on the usb stick without a problem. The dos computer couldn’t see it at all on the emulator, and after attempting it, the ipcas software couldn’t read the stick any more an wouldn’t reformat it, so it was scrap. I suspect, again, that the software formatted the stick as FAT 32, although it didn’t give an option for FAT 16.
So I am reckoning that the main problem is the FAT 32.
The floppy on the Anilam controller is a Sony, with the twisted cable at the floppy end, and I have been using exactly the same floppy make and model on the dos computer, and it works fine, so I am pretty sure that if I can crack this, and get the emulator to work on the dos computer, then it will work on the Anilam system.
Does anyone know how to get the usb stick formatted in FAT 16, or even if there is some dos software that will work on the dos computer.
I am not even sure if the firmware installed on the gotek which I think is flashfloppy, will even work with FAT 16.
If anyone else has found the way out of this, I would be grateful for some pointers.
