RiscPC always thinks disk is blank on first open
EmpireStateHuman
Post by EmpireStateHuman »
I'm trying to install an SD HxC floppy emulator in an Acorn RiscPC, but I'm hitting the same problem called out in a prior thread (viewtopic.php?f=19&t=1705&p=11626&hilit=riscpc#p11626) - essentially, the machine thinks the disc is empty the first time I mount a new image, but then correctly recognises the image upon a second attempt.
Can anyone help me resolve this? Thanks!
Re: RiscPC always thinks disk is blank on first open
EmpireStateHuman wrote: Sun Oct 02, 2022 7:36 am I'm trying to install an SD HxC floppy emulator in an Acorn RiscPC, but I'm hitting the same problem called out in a prior thread (viewtopic.php?f=19&t=1705&p=11626&hilit=riscpc#p11626) - essentially, the machine thinks the disc is empty the first time I mount a new image, but then correctly recognises the image upon a second attempt.
I think you need to change the interface mode to "ibm pc" See :
viewtopic.php?p=16503#p16503
