External connector question
gsargent
Post by gsargent »
On the pin header for the external (front panel) connector on the SD circuit board one pin is labeled LCD_BACKLIGHT in the manual.
Is this for the addition of a button to turn off and on the backlight?
I have ran the power for the backlight off of the +5v drop on the pin header since no voltage is going to that LCD_BACKLIGHT pin.
Thanks for the info
lotharek
Re: External connector question
Post by lotharek »
hello
1. LCD_BACKLIGHT_CTRL from PIC (pin7) feeds through R31 resitor Q3 tranzisotr and operates the presence of backlight. Simple and effective :-)
It is my first test to se if the pic was programmed correctly - if there is no backlight, pic is wrong programmed.
how to understand manual info about header :
- try to connect 16pin header BUTTON_UP with gnd. OK - what happens ?
all i mean, gnd is common in that header
ps. please, if You do not have some experience - do not play with soldering iron...it may cost you money and us precious time.
..... Atari Roxxx !!!
gsargent
Post by gsargent »
Guess you misunderstood me. I am talking about pin 10 on the front panel connector. Yes I understand how a basic switch works by connecting it to ground.
"ps. please, if You do not have some experience - do not play with soldering iron...it may cost you money and us precious time."
Just a suggestion that before you start telling people to not use a soldering iron maybe you should lighten up. I was trying to ask a simple question but instead got an insult. I thought maybe other people here might have had the same question, if not then I apologize to those people.
lotharek
Post by lotharek »
insult ? Where ? do not be so fragile ;-)
do not take it like that. just want to inform You, if You burn PIC there is no other way like get new one programmed. Postages costs and warranty doesn`t include burnt PICs change.
and i did UNDERSTAND You well.. i explained You the way backlight works, and in this moment You should know that SWITCH THERE MUST NOT be put.
with no offence of course, but i have had few of problems with people playing with "NOT PROPER" soldering irons and BURNT PICS TO DEATH .
Even me burnt few pieces at the beginning using inproper tools
gsargent wrote:On the pin header for the external (front panel) connector on the SD circuit board one pin is labeled LCD_BACKLIGHT in the manual.
Thanks for the info
This is an open collector driver.
The connection to use is :
+5V pin -> (Anode-Backlight Led-Cathode) -> LCD_BACKLIGHT pin
gsargent
Post by gsargent »
lotharek,
Sorry didn't mean to snap like that. Bad day for me and I just took it the wrong way. Please accept my apology :)
Ok looks like I just need to do a bit of rewiring. I had it as follows
+5V pin -> (Anode-Backlight Led-Cathode) -> GROUND pin
Thanks Jeff for a fantastic design and thanks lotharek for a quality made product.
