Kryoflux RAW to HFE Procedure?
IBMPortablePC
Post by IBMPortablePC »
Jeff helped me out with creating a HFE image from my Kryoflux files (Thanks again, Jeff!).
He explained that he: “i have just used your kf raw files, removed the unformatted side and tracks, fixed the bitrate to 250000 and finally export it to hfe. you can figure out the used disk parameters with the disk/track viewer.”
I believe that this equates to:
1. Delete Tracks 81-83 & side 1 i.e. .1. files
2. Load the raw file - Select Track 0 RAW file (all other tracks are then automatically loaded).
3. SDCard HxC Floppy Emulator Settings -> HFE File interface mode set to Generic Shugart
4. Track Analyzer -> Edit tools -> Set Disk Bitrate 250000
5. Export to HFE.
However, I am not 100% certain. Is there a documented procedure?
I have based my interpretation above on searching the forum and finding:
Load the raw file, SDCard HxC Floppy Emulator Settings -> HFE File interface mode set to IBM PC 1.44MB interface mode -> Track Analyzer -> Edit tools -> Set Disk Bitrate 500000 -> Export to HFE.
viewtopic.php?t=2005
Re: Kryoflux RAW to HFE Procedure?
your method should work but all can be done with the "Edit tools" as well.
