SFRKC30.AT2 fw 3.3 loading saved games
PrinceEugen
Post by PrinceEugen »
Hi, I have an issue with gotek board SFRKC30.AT2 with flash floppy fw 3.3 stable version (bought flashed from store).
Usb with .adf files is fat32 formatted. Beside those .adf files there are also two files in root folder of usb (autoboot.hfe and hxcsdfe.cfg).
Configuration is amiga 500 with 512 chip RAM + 1.5MB fast RAM + kick 1.3.
Loading .adf files works properly, but the problem is with game save discs. Amiga successfully creates save game disc (Dune 2, Sensible Soccer...) with empty disc created via WinUAE but it shows Disc error when loading saved games.
Referred issue does not appear in WinUAE software with mentioned games and their .adfs so saving and loading via game discs works properly.
JC jumper on the board is not marked but that position is open as it should be for Amiga.
How to resolve this or is there any additional configuration ?
Thx.
PrinceEugen
Re: SFRKC30.AT2 fw 3.3 loading saved games
updated fw to 3.32, issue remains. disk error
This is the wrong place / forum to ask support for this firmware. You are here on the HxC Floppy Emulators / firmwares support forum.
PrinceEugen
ok, sry.
can you delete this this post. i will go somewhere else to resolve my issue.
cheers.
