Write support for the Amiga (Firmware V1.3.0.0)
carlcala
Post by carlcala »
RE: Write support for the Amiga (Firmware V1.3.0.0)
I'm interested in the SDCard HxC Floppy Emulator. I have noticed that there is now the WRITE support for the Amiga...wow Great update for a great emulator. I would like to clarify the following prior to purchase:
If i buy the SDCard HxC Floppy Emulator, will it be possible to have the card updated (to Firmware V1.3.0.0) with the WRITE support including the new componenets on the emulator for the AMIGA 500? I can't imagine myself fiddling with components :)...i'm not technical at all.
Is the SDCard HxC Floppy Emulator compatable with an Amiga500 with a kick rom switcher having Kick rom 1.3 and 3.1?
Regards and congratz... :wink:
Keep up the good work
Carlo
javidoom
Post by javidoom »
Hello
And yes, the HxC is perfectly compatible with this amiga 500, I have the amiga 600 with the same switch to select kickstart and works flawlessly :)
(Edited removing bad info).
lotharek
Post by lotharek »
for a moment AMIGA WRITE SUPPORT is upgrade to REV B.
New board will appear...hmmmm...i do not know :-)time will show.
costs of intrudicing new board are very very high....
..... Atari Roxxx !!!
carlcala
Post by carlcala »
So Lotharek, is it possible to upgrade it with the relevant components for me? How much will this cost?
Regards
Carlo
javidoom
Post by javidoom »
carlcala: I've bought the components for less than 3€ total.
I hope tomorrow to upgrade mine :)
javidoom wrote:carlcala: I've bought the components for less than 3€ total.
So you will be the first Amiga user with the write support ;-)
lotharek
Post by lotharek »
hmmm,..i think the third one :-)
So it is working for you Lotharek ?
javidoom
Post by javidoom »
Hello
I'm trying right now, but doesn't work :(
I've checked many times everything is right soldered, but no message appears, and the amiga don't write...
I have firmware 1300 and the new bootrom .
What can i try?
javidoom wrote:Hello
What can i try?
Please make a picture of the modification and post it.
Another try : remove the lcd screen and try to write somthing under the WorkBench.
javidoom
Post by javidoom »
Hi
Thanks for the fast answer.
I'm trying now to upload the images to a server. will post in a min.
I'm trying too, to upgrade (again) the bootrom (maybe I had an error the first time???) I've been using firmware 1300 without problems.
Trying to upgrade again the bootrom, I get an error of 5 flashes (corrupt archive). :? Maybe it's because I ALREADY have it installed...
The others cables in the pictures are for case I've made for it.
http://img832.imageshack.us/img832/1074/lafoto1.jpg
http://img137.imageshack.us/img137/9606/lafoto2u.jpg
http://img840.imageshack.us/img840/5777/lafoto3.jpg
http://img841.imageshack.us/img841/2124/lafoto4.jpg
http://img841.imageshack.us/img841/7984/lafoto5t.jpg
I'll try in the meanwhile to disconnect the display and try to write something.
No luck, without the screen, appears as saved in the disk, but after reboot, the disk is again blank.
Thanks!!
Try to reduce a little the wire lenght. The sram communication is done at high speed (10mhz).
You can connect pin 7 & 8 together. No need of 2 wires for VCC3V.
If still doesn't work try to remove R5.
If still doesn't work change the value of the resistors to 100ohms. (EDIT : Are you sure that you are using 220ohms resistors ?)
javidoom
Post by javidoom »
Many thanks for the tips.
I'll make the changes along the night and will post the results.
Thanks again!
Edit: yes the resistors are : red red brown
javidoom wrote:Many thanks for the tips.
Thanks again!
STop i have found the problem !!!
I will upload a new firmware version !
javidoom
Post by javidoom »
Cool!!!
You're the best. :)
Waitinngg ;)
