Yamaha QY700 Bad Disk
wbendick
Post by wbendick »
Hello, I am trying to use a Mono Tanz Floppy Drive Emulator in a Yamaha QY700. I am able to read disks correctly but whenever i try to do any write operations (save, rename, delete, format disk) the operation will proceed, I see the emulator writing blocks but at the end the QY700 will give the error message "Bad Disk" and the disk written to will appear to then be in a corrupted state.
I have jumpers on the pins labeled S1 and also on JC.
Can anyone suggest anything to try?
Re: Yamaha QY700 Bad Disk
What can you read on the gotek screen when no usb stick is inserted ?
wbendick
Post by wbendick »
It says "FlashFloppy v3.23"
