I have a gotek that was flashed with 'flash floppy', and I am trying to load the unit with the HxC firmware.
I tried using the STM32_SerialBridge with ny Gotek/Artery device, but the SerialBridge always reports a 'device error' when connecting to the gotek, even when I tried swapping the Rx/Tx connections.
Following the instructions under "ARTERY Gotek USB A to USB A cable firmware installation".....
The ArteryISPProgrammer does communicate with the unit using the USB A to A cable and I get most of the way through installing the bootloader until steps 9 & 10.
At step 10 I can find no file "hxc_fw_installer.hex" to add. I have search every unpacked zip-file with no luck, and google doesn't find it on the web.
Where can I find/get "hxc_fw_installer.hex" ??
Gotek Artery difficulty with bootloader install
Re: Gotek Artery difficulty with bootloader install
For such support request i recommend you to contact me by email.
After the firmware registration (https://hxc2001.com/store) you should have received an email with all the needed information.
newmichael
Hi,did you end up finding the hxc_fw_installer.hex file?I'm still struggling to find it because both hxc2001@hxc2001.com and activation@hxc2001.com didn't reply ,thanks!
