LBA change error
repairlab
LBA change error
Post by repairlab »
Hi guys,
I finally managed to flash my gotek (had to set my dongle serial port from 12 to 2 to detect the STM32) and after updating it using the file in the "On_Screen_Display_Firmware" folder to make the small OLED screen work and copying the Amiga files it boots with error:
"LBA Change Test Failed, Write Issue?"
Please advise.
br,
george
https://www.icloud.com/photos/#07er3ZWh ... m7As51m1pw
repairlab
Re: LBA change error
Post by repairlab »
apparently the retroninja external floppy adapter seems to cause some conflict.. if I place the gotek internally it works..
other issue it that the USB stick is not detected when powering on - I have to re-insert it.
Which usb stick are you using ?
repairlab
Post by repairlab »
using a pretty old 256mb one ...could this be the problem?
repairlab wrote: Sat Mar 26, 2022 11:05 pm using a pretty old 256mb one ...could this be the problem?
I think i have fixed the issue. Since the issue was in the bootloader, flash it again (using the email or the serial method).
repairlab
Post by repairlab »
hi Jeff,
so you mean you fixed some bug?
I did flash it again today using serialbridge and then updated it blindly to get OLED output but the USB is still not detected on power on.
see video here:
https://www.icloud.com/photos/#086o8Ke0 ... sgipzQMAkw
any ideas?
apologies for the crap video.
repairlab wrote: Wed Mar 30, 2022 10:16 am hi Jeff,
see video here:
any ideas?
Can you please try the latest firmware version ? : HxCFEUSB_V4_2_8_4a.UPD
repairlab
Post by repairlab »
where can I get that file? mind you I need the version that supports the small OLED screen.
EDIT: I found it in the WIP folder!
same results:
https://www.icloud.com/photos/#0a9yTud7 ... BGy3X76DgQ
repairlab wrote: Fri Apr 01, 2022 11:26 am where can I get that file? mind you I need the version that supports the small OLED screen.
same results:
This may be an power supply issue, but please wait 10 seconds before removing the stick, the emulator try to reset the usb stick every 4 or 5 seconds with this version.
repairlab
Post by repairlab »
perfect thanks I will try all options!
