REV F - HXC SD Floppy Drive Emulator Pin 34 setting > nReady2
medlab
Post by medlab »
I have two HXC SD REV F, one with software version V1.8.2.40 LC is giving me an option on the Setting Menu > Interface CFG > Custom > Pin 34 setting > nReady2 and works well with my machine. The other one HXC SD REV F doesn't give me this option (Pin 34 setting > nReady2) at all.
I tried all available firmware on the website, and none of them is provide this option.
It is important for my machine to have Pin 34 setting > nReady2.
What should I do?
Re: REV F - HXC SD Floppy Drive Emulator Pin 34 setting > nReady2
Please find attached the requested firmware.
HXCFE_V1_8_2_40_LC.upd
(59 KiB) Downloaded 861 times
medlab
Post by medlab »
Many thanks Jeff, everything worked out well.
If anybody needs to use the REV F - HXC SD Floppy Drive Emulator on Roche Elecsys 2010 analyzer, this firmware is essential.
Thanks once again.
medlab
Post by medlab »
Hello Jeff, do you have any seller for the HxC in Germany? I need to buy another SD FW - HXC Rev F.
A friend of mine has a gotek USB drive, can he use it with the proper firmware and software to work on the Elecsys 2010 (nReady2)? What should he do?
Eav_1365
Post by Eav_1365 »
medlab wrote: Thu Feb 24, 2022 3:52 pm Many thanks Jeff, everything worked out well.
Thanks once again.
Hi. I have same problem. Please help me. My email address is:ttzgrp@gmail.com please give me a way or link to send you email and get help from you
