SD FW - HXC Rev F Front Plate Plans
rbarrios
Post by rbarrios »
Hi!
I have installed the SD FW - HXC Rev F WHITE CASE and I would like to mill a metal front panel to avoid using the plastic sticker which does not look right on my instrument. I was going to measure all dimensions, but I though those might already be avilable. Is it possible to get the plans of the front panel to mill my own? (I will share the result with you anyway)
Thank you,
Roberto
Re: SD FW - HXC Rev F Front Plate Plans
but the plastic sticker can be removed, isn't it ?
rbarrios
Post by rbarrios »
Hi Jeff!
Yes, it can be removed but no need because I did not even put the sticker on the adapter. Nevermind, I will make the measurements myself.
Best regads,
Roberto
rbarrios wrote: Tue Jan 11, 2022 12:19 pm Hi Jeff!
Best regads,
Roberto
Anyway way you can find the dimensions in this pdf :
https://lotharek.pl/files/sdf/SDFdimensions.pdf
rbarrios
Post by rbarrios »
Hi Jeff!
Perfect, that is exactly what I need. I'll let you know how it goes. Thank you!
Roberto
