SSSD 5.25 with 18 sectors pulses Index too slow
MECCABINGO
Post by MECCABINGO »
USB Rev D Cased
A 5.25" floppy at 300rpm should generate an index pulse every 200mS
If I create a SSSD Blank floppy with 18 secotors per track, which I think is fine,
I get an index pulse every 400mS.
If I reduce the sectors to 9, it behaves and gives 200mS.
Have I done something wrong, or is the emulator misbehaving?
Regards
Keith
Re: SSSD 5.25 with 18 sectors pulses Index too slow
You need to set the bitrate at 250000 kbits/s. (In FM you need a data bit + a clock bit. So to have a 125000 kbits/s data rate you need to double the bitrate (data + clock))
MECCABINGO
Many thanks! Good things are happening at 250,000.
