Floppy replacement for different old keyboards .
venkecske
Post by venkecske »
Here in Hungary there are use a lot of kind old synthetisers , which have defective floppyes, or if it maybe works - uncomfortable.
These are most the Roland series. These use Panasonic Ju257A166p, Ju257A768, Teac FD230, and so on... with different settings.
Has the HxC emulator some solution to exchange these floppyes?
Is there possibility to change DS0/DS1 , and can it handle the ready signal?
Thank you in advance :
venkecsi
Re: Floppy replacement for different old keyboards .
venkecske wrote:Here in Hungary there are use a lot of kind old synthetisers , which have defective floppyes, or if it maybe works - uncomfortable.
venkecsi
Yes the HxC Floppy Emulator can replace 1.44MB floppy disk drive and handle the ready signal.
For more details have a look to the user manual:
and to the software :
Which kind of floppy disk images can be used with these keyboards ?
