Gotek wont start after update
xunillo
Post by xunillo »
Hi all,
I just bought a gotek from amigastore.eu with HxC firmware. I tried the procedure on the website to update the firmware.
The Oled was completely black during the procedure. Now after few minutes wont work.
If i reboot the gotek it doesn't show anything on the OLED. When it starts it is doing some green blink five times and stop.
I've tried to buy again the HxC bootloader and I'm trying to put f_hxc_fw_installer.upd, EXCHANGE.BIN and the last HxC firmware version (HxCFEUSB_VX_X_X_Xa.UPD. Anyway is doing the same. only 5 blink and stop. I don't know how to move forward :-(
Re: Gotek wont start after update
You have an Artery Gotek, You need to use the V4.x.x.x firmware (HxCFEUSB_V4_0_5_2a.UPD present in the "WIP_Firmware")
xunillo
Post by xunillo »
Ok thank you now the firmware and OLED back to work.
I finally found the issue on the external adapter. the jumper was misconfigured. now it works! thank you for your support
