Spectum and Sam
caver99
Spectum and Sam
Post by caver99 »
Is it possible to implement the MGT disk format into this so it can be used with aPlusD and a sam Coupe?
Re: Spectum and Sam
caver99 wrote:Is it possible to implement the MGT disk format into this so it can be used with aPlusD and a sam Coupe?
Maybe, did you have some files somewhere and/or a file description ?
caver99
Post by caver99 »
I can get some mgt and sam disk images for you.
caver99
Post by caver99 »
SAm Coupe disk format is 80 track 10 sectors with 512 bytes per sector - http://en.wikipedia.org/wiki/SAM_Coup%C3%A9#Disk_drives
caver99 wrote:SAm Coupe disk format is 80 track 10 sectors with 512 bytes per sector - http://en.wikipedia.org/wiki/SAM_Coup%C3%A9#Disk_drives
And the MGT file format is a raw file format ?
caver99
Post by caver99 »
This is a section taked from the tecnical manual for the plus d
"6. DISK LAYOUT
The disk has 80 tracks of 10 sectors (512 bytes double density, 256 bytes low
density) each, for a total capacity of 800KB (DS/DD).
The first four tracks of the disk (tracks 0-3 side 0) are reserved for the
system and contain the disk directory, leaving 780KB available for user data.
The directory consists of 80 consecutive file descriptors, each one taking
256 bytes; thus, the descriptor of file #48 resides in the first 256 bytes
of sector 4 track 2.
The directory has a fixed dimension and can only contain up to 80 files.
UNIDOS overcomes this limitation introducing subdirectories and allowing to
specify the maximum number of file entries for each directory.
Disks formatted with DISCiPLE or +D can be read and written by common PC
disk drives and viceversa"
Hope this helps
caver99 wrote:This is a section taked from the tecnical manual for the plus d
"6. DISK LAYOUT
Hope this helps
Could you give me some link to some images ?
caver99
Post by caver99 »
Yeh no probs see below:-
Sam Coupe:-
http://romhustler.net/roms/sam/all
MGT Plus D
Below are 2 links from WOS but is you goto search and type +D a lot more come up.
http://www.worldofspectrum.org/infoseek ... id=0014744
http://www.worldofspectrum.org/infoseek ... id=0008570
caver99 wrote:Yeh no probs see below:-
Sam Coupe:-
MGT Plus D
ok sad and mgt are pure file format.
So to load them you can use the "Load Raw Image" button, and set "Sector per track" to 10 and "GAP3 lenght" to 34.
After this click on "Load Raw file" and choose your sad/mgt file image.
I will released a new version of the tool to make these steps easier.
caver99
Post by caver99 »
Thanks for that.
I have had a go but comes up saying disk missing, dont surpose you have have any idea what setting i would use for j3?
caver99
Post by caver99 »
Its ok found manual and set it to a: works a treat many thanks.
Would this be possible to have in the software so we can just load them in.
Just a thout love thsi so far.
caver99 wrote: Would this be possible to have in the software so we can just load them in.
Yes, i will do it this week.
caver99
Post by caver99 »
Just found out that games like manic miner and prince of persa wont convert might be because they have protection on them.
caver99 wrote:Just found out that games like manic miner and prince of persa wont convert might be because they have protection on them.
What means "wont convert"? the game is not working ?
caver99
Post by caver99 »
when i load the file as a a raw file adn the conver/save as and then copy the .hfe file to sd card and view it on the sam its empty but useing the .sad file in the sam emulator its fine.
