I search a step by step guide for the S950
MartFou
Post by MartFou »
Where I could find a "step by step" guide to install and configure a GOTEX HxC Floppy Drive Emulator on a S950?
There is many thread in the forum that try to offer solutions, but I don't find a post that explains and share the links of firmware/tools/image we need to do it from scratch to the end.
Also, I plan to buy this GOTEK model, is it a good choice ?
https://a.aliexpress.com/_mPd7eGW
Thanks to all
Re: I search a step by step guide for the S950
Here are the mains steps
- Get the firmware : https://hxc2001.com/store/
- Install the firmware : https://hxc2001.com/docs/gotek-floppy-e ... ation.html
- Copy some S950 files images to the stick : https://hxc2001.com/download/floppy_dri ... Images.zip
- Set the S0 jumper, remove all others jumper and place the Gotek into the S950.
MartFou
Post by MartFou »
Thank you @Jeff for your detailed answer.
Could you explain me the difference between this link :
and this one :
