Hi.
Had heaps of issues trying to do the original flashing process.
It can see it in the com port, connection to the HXC Serial bridge is up.
Then i get "Serial Bridge is Too Old" - download a new version, which i have done.
Does it mean that the serial adapter which is one of these:
https://core-electronics.com.au/usb-to- ... Y4QAvD_BwE
Is this more than likely software or the Serial device..
Any help appreciated
CHeers
CM
Firmware Too Old
Re: Firmware Too Old
This means that you need to update the software :
https://hxc2001.com/download/floppy_dri ... Bridge.zip
Hi
Yes i have downloaded the latest and i am still getting the too old error, so was wondering if this has come up anywhere else??
Cheers
Cheers
Then this means that you have a network issue. Please contact me by email to use an alternate flash method.supercruiser wrote: Sun Oct 03, 2021 8:50 am Hi
Cheers
