Not able to read files on a 2MGUI-formatted image
jose1711
Post by jose1711 »
I've made a dump of a 2M-GUI formatted flopy to a RAW format using Kryoflux. HxCFloppyEmulator is able to load it as it's using MFM-encoding. I see the data in track/stream view:
However due to a non-standard format the DOS Floppy Disk File browser does not show any files:
Tried all filesystem types in the pulldown menu. Is there any chance to support this (and also 2M) format?
Thank you, jose
Edit: Improved formatting.
Re: Not able to read files on a 2MGUI-formatted image
Can you share this dump ?
jose1711
Post by jose1711 »
Kryoflux dump is located at https://ufile.io/ykkx6owg
The floppy contains two files - PDF and a text file containing BSD license.
