Mirage not reading files from gotek
zaazanbou
Post by zaazanbou »
I'm quite new to this world, so sorry if this is an easily fixable problem and I'm just being a bit of an idiot.
So my Gotek usb reader drive thingy (which has been updated to the most recent firmware) isn't communicating with the mirage. when I put .hfe files on the usb stick (I've tried OS3.2 and a couple of other .hfe and .edm files) none of them are being read by the mirage.
please help me try and figure out what is going on!!!
thanks,
hudson
zaazanbou
Re: Mirage not reading files from gotek
Post by zaazanbou »
I should probably clarify that the mirage says nd when turned on even with a usb with the correct files inserted.
the mirage works fine with the original floppy drive inserted with and loads os32 fine
Is the jumper set to S0 ? Have you tried to reconnect the floppy ribbon to the other way ?
