Emulator II not loading OS
bracken
Post by bracken »
I installed an HxC SD drive in an Emulator II. After considerable messing about I got it working, and it worked great. I took the circuit boards out to replace caps and IC sockets. I put it back together, and the OS no longer loads. On power-up, the Emulator displays "Emulator 2 - Boot in Progress." The HxC drive displays "AUTOBOOT.HFE T:000/080 S:0" or the filename of whichever file it was set to load most recently. I've used HxCFloppyEmulator to change the autoboot options - the HxC drive follows the directions in the HXCSDFE.CFG file, but doesn't load any OS.
Any thoughts on why it's not working any more, and how to get it going again?
bracken
Re: Emulator II not loading OS
Post by bracken »
Anybody?
bracken wrote: Mon Sep 06, 2021 8:39 pmAnybody?
Can you try the images and config file available for the Emulator II in this archive :
