Gotek OLED/Rotary with push botton, Normal mod
gseb
Post by gseb »
I have the config from the title with latest Firmware.
When I eject an image by pressing on the rotary encoder button, after a few seconds it load it again without I touch anything.
It seems there is an auto-load function somewhere... Can I disable this or I did a mistake cabling the encoder ?
Thank you in advance.
Seb
gseb
Re: Gotek OLED/Rotary with push botton, Normal mod
Post by gseb »
Just found the menu with settings when removed the USB stick ! :-)
gseb wrote: Tue Jul 13, 2021 8:31 pm Just found the menu with settings when removed the USB stick ! :-)
Yes this is a way to change the auto select function.
