Akai S3200XL & Gotek (v3.4.16.10) no disk issue
Shaun
Post by Shaun »
Hi all,
I have the Gotek fitted in an Akai S1000 with no issues and also I have the v3.4.16.10 fitted in an Akai S3200XL with this no disk issue. Firstly if I insert a working thumb, ie has the OS and config files, etc, the first time I hit load I get a "no disk" error then the second time the files appear... Which seems a little strange. If I use EMXP to create an S1000 image from some sound files and then and drop it to the thumb drive it will not read it - Do I need to convert the HFE from S1000? Or possibly use a diff program to EMXP? sorry bit of a noob
Is it possible I have the jumper settings wrong?
All advice would be apprieciated!
Shaun
Re: Akai S3200XL & Gotek (v3.4.16.10) no disk issue
Shaun wrote: Thu Jun 03, 2021 1:16 am Hi all,
Shaun
For the S3200XL you need to change the interface mode to ibm pc hd. Have you an oled screen on this gotek ?
Shaun
Post by Shaun »
Thanks so much Jeff, that is exactly what it was!!
For anyone reading with the same problem:
I did have the OLED version and pressed both buttons on the front to enter the menu. I changed 'system family' to AKAI and I changed 'interface CFG' to IBM PC HD (as suggested) and it's working like a dream
