Getting files from within the .hfe off the SD card
KayproDude
Post by KayproDude »
How do we get files from within the .hfe off the SD card.
Have a fully working Kaypro2 and the HxC Emulator. Wordstar created a document and saved.
remove the SD card, inserted into my windows 10 computer. I see the .hfe file, and opened the HxCFloppyEmulator v2.5.6.6, I dont see a way I can explore browse files in that .hfe virtual image file. I need to get into the .hfe file and copy the text file.
Re: Getting files from within the .hfe off the SD card
which file system use the kaypro2 ? cp/m ? fat ?
KayproDude
the SD card is FAT, the disk image .hfe is CP/M
KayproDude wrote: Thu Jun 03, 2021 9:37 pm the SD card is FAT, the disk image .hfe is CP/M
For the CP/M :
viewtopic.php?p=23732#p23732
Use cpmtools to create/edit/access a cp/m dsk image and once done convert it with the hxc software to hfe.
http://www.moria.de/~michael/cpmtools/
