Reading DMF-formatted disks
mbalmer
Post by mbalmer »
Any time I use a DMF-formatted image with my Gotek, I get "sector not found" errors when trying to read them. Is something misconfigured, or can I not use this format with the HxC firmware?
Re: Reading DMF-formatted disks
Sure you can use DMF format. But can you share one of these DMF file ?
mbalmer
Post by mbalmer »
Sure -- When installing either Windows 95 or 98, the second disk always fails to read during setup. I tried to just copy over the files in DOS as well and got "sector not found" errors.
I can't seem to attach it here (file too large). I can email it?
mbalmer wrote: Sun May 16, 2021 7:39 pm Sure -- When installing either Windows 95 or 98, the second disk always fails to read during setup. I tried to just copy over the files in DOS as well and got "sector not found" errors.
I really need the images to diagnose the issue. Where have you downloaded them ?
mbalmer
Post by mbalmer »
Windows 95 came from winworldpc.com. They're the install disks for the floppy edition of Win95OSR2.
The Win98 floppy disks came from vetusware.com.
Can you try to convert these images with the HxC tool to HFE and tell me if you can read them :
mbalmer
Post by mbalmer »
After conversion to the HFE format, the disks read fine.
mbalmer wrote: Tue May 18, 2021 9:29 pm After conversion to the HFE format, the disks read fine.
Ok i will check the internal table and fix it for the next version.
