ZX Spectrum +3 conection
kikems
Post by kikems »
What´s the correct jumper config and cable conections to conect SDCard emulator as external drive B on spectrum +3 ?
I´m conected like an amtrad cpc jumper config for drive B and the cable with conected jumped pins 24 and 23 , but not works.
Re: ZX Spectrum +3 conection
kikems wrote:What´s the correct jumper config and cable conections to conect SDCard emulator as external drive B on spectrum +3 ?
If you want use the external disk drive connector, try to put the jumper in the id1 position, without the jumper on pins23/24.
Perhaps the Floppy cable should be reverted on the hxc floppy emulator.
