Refreshing floppy
SuperF4
Refreshing floppy
Post by SuperF4 »
So my gotek was working fine when I installed the disk images for msdos 6.22. All the disk images worked fine as I changed from floppy to floppy with the button, but while I'm in Dos 6.22 and trying to install some games, it only shows the disk I have emulated at the moment and when I try to change it will not refresh to show me the next disk. If I hit ctrl c and then do a dir /w search, it will refresh and show me the correct disk. Any one have similar issues with the gotek not refreshing the emulated disk when you hit the next button?
Re: Refreshing floppy
Which firmware is installed on this Gotek ? What can you read on the Gotek's screen without usb stick ?
