HxC floppy emulator on Amiga 1200, second virtual drive disappears after reboot
jigar24
Post by jigar24 »
I've recently purchased a HxC/Lotharek SD Card floppy drive emulator. It's working well replacing DF0: but I'm seeing some odd behaviour with its emulation of DF1:.
On the first boot after power-up, the Amiga detects both DF0: and DF1:. But after a reboot, DF1: disappears.
The HxC does seem to be jumpered correctly (DS0 connected to drive A, DS1 connected to drive B) and there are no other drives, internal or external, connected.
What could be causing this problem?
Re: HxC floppy emulator on Amiga 1200, second virtual drive disappears after reboot
Is an image loaded in the DF1 drive ? You may need to force the Amiga interface mode in the embedded menu.
EDIT : The previous post finally appears to be posted by a spambot :shock: :
The original post come from this page : https://retrocomputing.stackexchange.co ... ter-reboot
Smart, isn't it ? :wink:
Btw there is the solution to this issue in the answers.
