SDCard HxC Floppy Emulator and old CNC Machine
ziotibia81
Post by ziotibia81 »
Hi!!
I've an old CNC machine with an old PC Floppy.
I'm planning to remove old floppy and install SDCard HxC but i can't know if it work or not.
Floppy Drive on cnc machine is a standard pc floppy but foppy disks was fomatted on a custom unducumentated mode. I already tryed to create a raw image from a floppy disk using rawrite on windows and dd on linux but all repord error on reading track 0. On CNC machine all work fine...
Someone could suggest me how extract a RAW image from this floppy, understand format type and discover if it could work using SD HxC ??
Bye...
Re: SDCard HxC Floppy Emulator and old CNC Machine
ziotibia81 wrote:Hi!!
Bye...
First solution :
ImageDisk under MS DOS
http://www.classiccmp.org/dunfield/img/
IMD file format are directly by the HxC Software.
Second solution :
OmniFlop under windows :
http://www.shlock.co.uk/Utils/OmniFlop/OmniFlop.htm
ziotibia81
I've tryed ImageDisk under MS DOS but it report a read error on track0.
I've no idea how my CNC save data on the floppy :(
ziotibia81 wrote:I've tryed ImageDisk under MS DOS but it report a read error on track0.
If you want you can send me your floppy disk to this address, i will have a look :
