HxC emulator with non ATARI system
xarion
Post by xarion »
Hey guys, is there any chance that the emulator would work on a machine other than the atari system. we have an old pick and place machine that uses floppy's and would like to replace it with an SD-floppy-emulator. The drives that are currently installed have have an edge connector. Is there possibility that the HxC would work in there?
Thanks in advance :)
Xarion
Re: HxC emulator with non ATARI system
xarion wrote:Hey guys, is there any chance that the emulator would work on a machine other than the atari system. we have an old pick and place machine that uses floppy's and would like to replace it with an SD-floppy-emulator. The drives that are currently installed have have an edge connector. Is there possibility that the HxC would work in there?
Xarion
Of course this possible :
https://hxc2001.com/floppy_drive_emulat ... SSUPPORTED
You can consider the HxC FLoppy Emulator compatible with your equipement if the original floppy disk drive use a 34pins connector (edge or not).
xarion
Post by xarion »
Excellent!! where do i sign up :) ? where's the easiest place to get the SD card version? I'm probably looking at buying around 8 if I get the one to work.
Xarion
xarion wrote:Excellent!! where do i sign up :) ? where's the easiest place to get the SD card version? I'm probably looking at buying around 8 if I get the one to work.
Xarion
Ebay (a new auction will be open soon) or on the online shop of lotharek :
http://www.mmj.pl/~lotharek/atari/
rwap
Post by rwap »
I also have a small stock of ones ready to ship, complete with printed manual - see http://www.sellmyretro.com/offer/detail ... ves%29-684
