Oberheim DPX1 floppy
k-Tracker
Post by k-Tracker »
Hello Jeff,
first of all I appreciate for your initiative, contribution and thousand of hours for developing emulator.
I started soldering SDcard emulator when it was free. I made it using prototype schematics and firmware on bread board full of wires but it works! )))) I tested it with PC but keep in mind future usage with Oberheim DPX1 digital sampler. From HW perspective it could be compatible (MS-ID0-RY) but disk image is a problem for me now.
I wrote email to person who developed PC utility for reading its disks and asked for help in configuring RAW parameters in your utility. I got following reply from him:
The DPX1 track format uses mixed sector sizes, so it can't quite be described using those format parameters. The PC floppy controller doesn't natively support them either, so I can understand the confusion from looking at Kris's code -- it actually formats using 11*512 bytes with a large gap3 length of 0xF1 to achieve it, but those values won't work in that program!
It might be worth getting in touch with the HxC project directly to ask about adding custom support for the image format, due to the problem with mixed sector sizes. It should be trivial to add if you tell them the DPX1 format and track order in the raw image file:
Format: 250Kbps MFM (@300rpm), 80 cyls, 2 heads, 6 sectors/track (5*1024 + 1*512), sector IDs 0 to 5, original gap3 unknown.
Disk image track order: c0h0, c0h1, c1h0, c1h1, c2h0, ...
Can you please help me to make this image compatible?
And another small question - If you'll make these changes in SW, will prototype FW(v0.2.2.0) be compatible with that? If not I'll buy production version :)
Re: Oberheim DPX1 floppy
k-Tracker wrote: Can you please help me to make this image compatible?
Yes no problem. Did you have some floppy images somewhere ?
k-Tracker wrote: And another small question - If you'll make these changes in SW, will prototype FW(v0.2.2.0) be compatible with that? If not I'll buy production version :)
Yes for the moment HFE file format is the same for prototype and production version.
k-Tracker
Post by k-Tracker »
Jeff, thank you for the answer.
Here is the image for example:
http://www.deftaudio.ru/files/DPX1/001.DPX
The tool for writing:
http://www.deftaudio.ru/files/DPX1/Dpxtools.zip
And sources for this tool:
http://www.deftaudio.ru/files/DPX1/Dpxtools_source.zip
DPX file support added!
Please give me a feedback.
k-Tracker
Post by k-Tracker »
Jeff, :shock:
I'll test it as soon as possible and leave my impression then.
Thank you - Thank you - Thank you
k-Tracker
Post by k-Tracker »
Hello Jeff,
quick update here - it works like a dream!
I'll post video and photos in few days.
k-Tracker
Post by k-Tracker »
Ok,
I've finally done with that project. Jeff, thank you.
There is few issues but all of them are from prototype FW I guess.
Scrolling is bad, first 3 symbols of file name are cut by displaying "r:0".
I've read newer FW doen't support prototype schematics and I am easy with that.
HW part - reading images is only one what I need :)))
Video:
http://www.youtube.com/watch?v=5G9UBxyhbOU
k-Tracker wrote:Ok,
Video:
Thanks for this nice video :D
Note:
If you have others synth or sampler with floppy disk drive , i am interested by supporting them !
Patoche7
Post by Patoche7 »
Jeff wrote:Note:
hi , and what about an emax I for Emu system ?
I have one from 1985 !!
See EMXP for image file and emulatorarchive for specification
:D
Patoche7 wrote:
Jeff wrote:Note:
:D
Yes.
Did you have some image files links ?
Patoche7
Post by Patoche7 »
Patoche7 wrote:
Jeff wrote:Note:
:D
Yes.
I have severals images on my pc
how do i do ?
PS:sorry for my english , could we talk in french ?
Patoche7 wrote:
Patoche7 wrote: hi , and what about an emax I for Emu system ?
:D
Yes.
how do i do ?
oui là :
https://hxc2001.com/floppy/forum/viewforum.php?f=3
tuf
Post by tuf »
I'm having a hard time getting .eii images to work with my HxC. I'm not entirely sure of the process of converting an image with the software...is it enough to load the raw file and convert it or do I need to make sure all the image geometry is set before I convert the raw file?
Tuf
tuf wrote:I'm having a hard time getting .eii images to work with my HxC. I'm not entirely sure of the process of converting an image with the software...is it enough to load the raw file and convert it or do I need to make sure all the image geometry is set before I convert the raw file?
Tuf
what did you call a ".eii image" ?
