Software not loading problem
wavetable808
Post by wavetable808 »
After getting my SP1200 after a year of not using it I couldnt get a sound from it.
The software loaded but nothing happened - I thought maybe I had forgotten how to load a file.
The when I turned it on a second time I got a message saying the software is loading but then it gets stuck on that screen.
I'm wondering what the next steps I should take are?
It is the Rev F HxC emulator.
Thanks in advance
Re: Software not loading problem
have you tried to use the sp1200 files present in this archive ? :
wavetable808
Yes, I set it up a couple of years ago and it worked perfectly. Then I didnt use if for about a year and when I started it the first time the software seemed to load but I couldn't load a bank. The when I tried again the software didn't load and it just seemed to get stuck loading.
So all those files are already on the drive, unless I'm mistaken.
Thanks for your help
