Hxc can not more read and write
glain
Post by glain »
Sorry, asked directly, but I don’t know what I must search and my English is not the best.
I built a hxc in my sp-1200 and it works fine. I want do a hotswap from the floppy. I load the file from the floppy and connected the hxc. But something must be run wrong. There are only some confused letters and numbers in the display.
I put the sp-1200 off. Try the hotswap again. When I want save the led shines but nothing happens. The sp-1200 says, I must format, but it doesn’t run.
Than I want Boot from the hxc, but it doesn’t run. I can choose files, but the sp-1200 doesn’t read.
Could I damage the the power connector? I read something about this.
Thx for help.
Greetings from Germany.
Re: Hxc can not more read and write
Does the hxc still display something ?
glain
Post by glain »
Hello, the problem is solved.
I make a update and now it runs.
Thx.
