HXCFE Command Line Parameters
Muckypaws
Post by Muckypaws »
I'm trying to find a list of HXCFE command line parameters that I can use to convert SFC files to Amstrad DSK.
I can do this via the UI, however I'm scripting the process as I have a few hundred physical disks to convert.
Is there an online manual for the command line program? or can someone provide the actual command line syntax please?
I've tried
./hxcfe_cmdline/App/hxcfe -finput:./scp/RainbowIslands.scp -foutput:./cpc/RI.dsk -CONV:AMSTRADCPC_DSK -verbose -usb:0
Thank you :)
Re: HXCFE Command Line Parameters
"-usb:0" is to use a USB HxC floppy emulator ( https://www.youtube.com/watch?v=bZ4YdBl9mc0 , https://www.lotharek.pl/productdetail.php?id=43), not to convert files. Remove this argument.
