Error 5 after flashing
g4ugm
Post by g4ugm »
Folks,
Flashed a GoTek with the loader. It comes up LDR. Pop in a USB stick with the ".upd" file on and the display flashes then error 5. Tried a couple of USB sticks and a couple of software versions. Gotek has had FlashFloppy on before could that cause the issue?
Dave
Re: Error 5 after flashing
> Error 5 : (blink 5 time and 2 seconds pause cycle) Bad UPD File header! (bad file)
I think that you have an non-hxc upd file on your stick. remove any other upd file from the stick and copy the hxc firmware upd file to the stick.
g4ugm
Post by g4ugm »
I used a clean empty stick.
g4ugm wrote: Mon Jul 20, 2020 11:44 pm I used a clean empty stick.
mhhh which file are you using ?
Can you make a video of the issue ? I am not sure anymore what you call "error 5"
The upd files to use are in this archive :
g4ugm
Post by g4ugm »
Yes I use that zip.
Error 5 is a flashing "005" in the Gotek LED 3-digit 7-segment display.
g4ugm wrote: Thu Jul 23, 2020 1:14 am Yes I use that zip.
Ok, that's very very odd.
Try to reflash again the bootloader with the hxc flasher. (your gotek is already registered so no need to have a new license).
g4ugm
Post by g4ugm »
Jeff,
Well that is the next step. I feel that flash didn't quite complete or something like that. Will post here when its done.
Dave
