Lecroy LT244 Gotek
likeme
Lecroy LT244 Gotek
Post by likeme »
Hy all :-)
I try to install a floppy emulation in my old Lecroy LT224 (i love it;-)). The problem is now, i can´t write on the usb stick. The scope means the stick is write protect :? . It is also not possible to format or do anything else with the new interface. I press the printscreen knob , the led is blinking and that was it.... The seller says, it is IBM compatible and it should run without problems.
Best regards.
Christian
Re: Lecroy LT244 Gotek
likeme wrote: Tue Jul 14, 2020 12:59 pm Hy all :-)
Best regards.
Christian
Is the HxC firmware installed on this Gotek ? :
https://hxc2001.com/store/
