DPX-1 retrofit - library disk images?
CAdair
Post by CAdair »
I'm looking into retrofitting a DPX-1.
From what I understand, you can load all A9, E2, P2, and En banks from a Rev F HxC in the upper drive provided you convert the .EII images with DPXTOOLS E2DPX.
The part I am stuck on at the moment is where to obtain the .HFE files or original disk images of the four libraries without scavenging thirty-year-old physical diskettes.
Is there an original Oberheim DPX-1 library and compatible CDROMS also? Is there a resource for this, or better yet a link?
CAdair
Re: DPX-1 retrofit - library disk images?
Post by CAdair »
Nobody?
I saw references to "Quickinstall collections" but don't know what or where that is.
There are also references to the Yahoo Group which appears to have been deleted and backed up but the backup does not contain any libraries in the "links" section. The Group appears to still exist as just a landing page. Is this an IP issue? I know a lot of old CDROMS and outdated banks can just be downloaded as disk images for a small fee or free..
Reference to "Quickinstall collections": viewtopic.php?t=1603
Thread on deleted Yahoo Group: https://www.gearslutz.com/board/electro ... ths-4.html
Backup of Yahoo Group: https://drive.google.com/drive/folders/ ... kKn71n_e1x
Apparently dead Yahoo Group: https://groups.yahoo.com/neo/groups/emu ... -list/info
CAdair
Post by CAdair »
These are four disks of banks:
E-mu Systems Factory Sample Library for Emulator II
and three OMI Universe Of Sounds CDROMS:
OMI-55-101 Volume 1
OMI-55-102 Volume 2
OMI-55-103 Volume 3 Northstar
CAdair wrote: Sat Jun 20, 2020 10:13 am I saw references to "Quickinstall collections" but don't know what or where that is.
https://hxc2001.com/download/floppy_dri ... index.html
CAdair
Post by CAdair »
The library situation is under control.
Do all four complete instrument libraries and CDROMS fit onto one 8GB SD Card in a Lotharek? I'm trying to determine if a Gotek USB with or without a rotary encoder and OLED display is a better option than a Lotharek SD. What are the advantages/disadvantages between the two?
CAdair
Post by CAdair »
Do the quickinstall folders contain sound banks?
For the DPX-1, do you dump everything into the root of the storage device with one .CFG file, or are the different instruments E2, P2, A9, En, separated into folders?
