SYSINFO for Gotek HxC in HFE anyone?
kerussm
Post by kerussm »
Hello guys, fighting with gotek, got SYSINFO.PRG file that won't work in boot manager, I guess it needs to be HFE format but can't find any converter to have it done. Maybe someone have this program in HFE to post? All I need to do is to check how much RAM I have in my Atari...
kerussm
Re: SYSINFO for Gotek HxC in HFE anyone?
Post by kerussm »
dead forum?
No, just the week end.
Just use the hxc software, you have all you need in this software :
(Button "Disk Browser")
kerussm
Post by kerussm »
Thank You.
This is what I was using.
Edited one of the blank discs from Atari ST folder where I have included file SYSINFO.PRG
Problem is when I want to run it on Atari as it takes a while and comes out with error.
Tried also with only one image on gotek and HXCSDFE.CFG indexed file only.
Same with this ?
SYSINFO.HFE.zip
(93.62 KiB) Downloaded 3291 times
And are you at least using the HxC Firmware on this Gotek ? Which version have you ?
kerussm
Post by kerussm »
Thank You. Your image working perfectly.
Yes I'm with HxC on all my Gotek's and updated to latest.
kerussm wrote: Mon May 25, 2020 4:57 pm Hi Jeff,
Ok then this is just an "user" issue :wink: :
Use this :
> Select the Atari ST 720 KB format.
> Button Create disk
> Drag & drop the prg file on the browser window
> Export to HFE.
This is explained in the documentation :
https://hxc2001.com/download/floppy_dri ... al_ENG.pdf
Page 4.
