Some games not working, Gotek, Speccy +3, HxC
atanquerel
Post by atanquerel »
Using Gotek with firmware v3.3.1.2a, some games don't load, but some do. Particularly "Rolling Thunder",
https://www.worldofspectrum.org/infosee ... id=0004234
(+3 Disk Image)
I've tried the ones that don't load in FUSE and they are OK. Using default settings of drive, all else seems fine. Great product anyway, and great software!
Re: Some games not working, Gotek, Speccy +3, HxC
atanquerel wrote: Mon May 18, 2020 10:33 pm Hi,
(+3 Disk Image)
The current firmware version is v3.4.15.2a.
atanquerel
ok, can the firmware be updated easily? and where can I download it, is there a cost? thanks!
atanquerel wrote: Tue May 19, 2020 2:16 pm ok, can the firmware be updated easily? and where can I download it, is there a cost? thanks!
Easy, with an usb stick. This is free if you already have the hxc firmware installed :
atanquerel
Wow! That was the easiest firmware update I've ever done on a device! Unfortunately, still no difference for these games :(
I've tried the Spectrum family, and the Shugart interface CFG as well as the default. Strange how these games load on the emulator?
atanquerel
I'm getting a feeling with this game it's something to possibly do with copy protection, found a similar thread:
https://spectrumcomputing.co.uk/forums/ ... php?t=1277
atanquerel wrote: Tue May 19, 2020 11:02 pm I'm getting a feeling with this game it's something to possibly do with copy protection, found a similar thread:
Share the images and i will have a look.
Have you just tried to convert the DSK to HFE ? The conversion looks fine to me.
I am checking the DSK direct support in the firmware but the HFE version should works.
atanquerel
I'll give that a try, thanks.
atanquerel
Yes, .HFE file works, nice one thanks!
atanquerel wrote: Fri May 22, 2020 1:57 pm Yes, .HFE file works, nice one thanks!
I have fixed the issue in the firmware. Will release it quite soon. Stay tuned :D
ReadingSteiner101
Post by ReadingSteiner101 »
Hi, has the update been released since then? I ran into the same issue, although it's not urgent as the conversion to .hfe trick worked for me as well.
atanquerel
Yes if you go to the site there is an update, I haven’t done it yet either but I will do
ReadingSteiner101 wrote: Tue Jun 30, 2020 7:09 pm Hi, has the update been released since then? I ran into the same issue, although it's not urgent as the conversion to .hfe trick worked for me as well.
yes.
kattan
Post by kattan »
Edit Delete Report Quote
Post by kattan » Mon Jul 27, 2020 11:17 am
The new update V3.4.16.4a does fix some issues with some ZX Spectrum +3 .dsk games. However, I have a number of games that will cause the computer to reset either back to the 128K main screen or to the 48K screen! They all share the same behavior. These are:
Barbarian II, Dan Dare II, Dan Dare III, Double Dragon, Robocop and Turrican II.
Some other games show other types of errors like black screen or some weird patterns. These are
The New Zealand Story, Robocop II, Operation Thunderbolt, The Simpsons and The Untouchables 2 disk version (single disk version works fine).
Finally, I noticed that a couple of .dsk files will cause the Gotek to go into a seek loop: These are
Mega Box 1 and Rick Dangerous.
I hope you can fix these because there is no way to play this on a real ZX Spectrum +3 so far.
Thank you
