TRS-80 Model II with gotek
hallorant
Post by hallorant »
I've purchased and installed the firmware on a gotek, it seems to be fine. I'm using indexed mode with some disk images from https://github.com/pski/model2archive/t ... r/Software
The gotek comes up okay and I can switch between my 3 images (000 001 and 003).
I'm wondering if I need to setup something special for 8" emulation on the TRS-80 Model II?
What happens is the machine starts up accesses the drive then reboots. I sometimes get to a disk error screen in the os, but not too often.
Talking to other Model II folks, they have your hardware working, but I'm one of the first (or the first) to try HxC on gotek.
Any suggestions welcome.
Tim
Re: TRS-80 Model II with gotek
The machine is rebooting randomly ?
Verault
Post by Verault »
I know this is an old post but I have found no real evidence anyone has gotten a Gotek HXC to work on a TRS-80 model II or any other Big Tandy (TRS-80's with 8 inch floppy drives).
Can someone please verify if this is working and what the settings should be?
Verault wrote: Fri May 17, 2024 12:51 am I know this is an old post but I have found no real evidence anyone has gotten a Gotek HXC to work on a TRS-80 model II or any other Big Tandy (TRS-80's with 8 inch floppy drives).
Nothing special to do : just convert the dmk/jv3/dsk and that's all.
Verault
Post by Verault »
Jeff wrote: Sat May 18, 2024 12:13 am
But it doesnt work. Have you ever tried this on a real TRS-80 MODEL II (2 with 8 inch floppy drives)?
What's the issue ? what is the emulator behavior ? are you trying to read FM images ?
