error in manual?
maopa
error in manual?
Post by maopa »
When I have a look at the showroom ibm pc notes often tells id1 was jumpered. But the manual tells that id2 is for drive a but id1 is for drive select b. Drive select b doesnt make sense to be id1 so could this be a wrong example?
Re: error in manual?
maopa wrote: Thu Apr 02, 2020 10:53 pm When I have a look at the showroom ibm pc notes often tells id1 was jumpered. But the manual tells that id2 is for drive a but id1 is for drive select b. Drive select b doesnt make sense to be id1 so could this be a wrong example?
In fact this depend if you are using the floppy ribbon's twisted part or not. The "twist" on the ribbon exchange the drive selection signals.
