Is there a technical reason a Gotek device can't emulate both A: and B: drives simultaneously?
keenerb
Post by keenerb »
Subject says it all, really. I assume the drive select pins are possibly the hurdle, maybe it's hard-wired at a point you can't easily address with software.
Re: Is there a technical reason a Gotek device can't emulate both A: and B: drives simultaneously?
keenerb wrote: Mon Feb 24, 2020 12:44 am Subject says it all, really. I assume the drive select pins are possibly the hurdle, maybe it's hard-wired at a point you can't easily address with software.
- No second drive select line.
- All bus gating is software done -> Must be fast as possible.
- Drive/image switching reliability/timing concern.
- User interface in question : Sound to be a pain to change the image in drive B or A with only these two buttons... In fact this is the most serious issue.
- This feature is already on the normal SD HxC Floppy Emulators : I am really wondering how many use this feature :?
There is no impossibility (the second select line can be wired), but the interest is questionable, especially when you can get another Gotek for a couple of $.
keenerb
Post by keenerb »
Yeah I can see the interface issues being the primary concern, I was wondering about that last night.
I could only think that the third button/rotary encoder button could swap between A and B drives for interface rather than insert/eject disk...
I don't really think it's a feature I'd even use, other than possibly to have a permanent boot A: drive and then swap floppies in B:...
