MSX2 question.
javidoom
MSX2 question.
Post by javidoom »
Hello
First, let me say this HxC Floppy Emulator is awesome, it works flawlessly with my Amiga 600, Atari 1024 STFM and Amstrad 6128 :)
Now I'm trying to use it my MSX2 Philips NMS8245, but I can't get it to work...
I've done the cable adaptor shown in this pdf:
http://www.msxarchive.nl/pub/msx/mirror ... 245fdd.pdf
All I get when I type "files" to show the files in the disk, the monitor shows an error saying:
disk offline
I've tried switching pins 6 and 7 in msx conector, no luck. (Disk I/O error)
Tried too, to ground pin 34 too, no luck.
I have the HxC jumper in the same position as used for Amiga. (DS0 selected).
I've tested many times the cable adaptor and everything is conected ok.
Can anyone help me to get it to work?
Re: MSX2 question.
javidoom wrote:Hello
disk offline
Try to move the jumper setting to ID1#. With your cable MSX DS0 are connected to the pin12 of the floppy emulator. this is the ID1# disk drive select.
javidoom
Post by javidoom »
Thanks!!
That was it! :)
After that, I've changed again the pins 6 and 7 and this time it worked! :?
Maybe it had a bad contact making so changes...
Thanks again for your fast answer.
This is an awesome product, really!!
javidoom wrote:Thanks!!
That was it! :)
I also recommend you to upgrade your firmware :
mau_rizio
Post by mau_rizio »
wich msx has been tested, apart the philips 8245 of javidoom?
I would like to connect to a philips 8280.
Someone tested on msx1 using a disk interface like philips vy-0010?
Is there write support for dsk images?
Thank you :)
mau_rizio
PS: I ordered mine on sunday, when will be shipped?
mau_rizio
Post by mau_rizio »
Tested on msx2 Philips nms-8280: just replace the original :)
Tested on msx1 Philips vg-8020, tested connected to a philips vy-0010 disk interface: everything ok :)
Some pics if you are interested:
http://img828.imageshack.us/img828/8053/27082010027.jpg
http://img715.imageshack.us/img715/1631/27082010023.jpg
http://img818.imageshack.us/img818/6573/27082010024.jpg
The msx is playing Bold, a nice msx1 demo:
http://www.youtube.com/watch?v=rKqqOcTFVm0
Thank you for the great work :)
maurizio
