Roland MC-50 HxC Stuck in setup menu.
Andympeck
Post by Andympeck »
Hello. I have installed a Gotek SFR1M44-U100K. The firmware has been flashed successfully to V3_4_10_10a.
When I switch the unit on, it displays HxC, and then it appears to be stuck in the setup menu - 0 flashes, and then the setting of item 0 (19 - Roland, in my case).
I can increment the menu item numbers, and adjust the settings, but when I switch off, it simply comes back to the same menu. How do I get out of the menu, please. Also, how do I format the USB stick into sets of discs for the MC-50?
Thankyou in advance...
Re: Roland MC-50 HxC Stuck in setup menu.
