Oxford electron microscopy
mrdavoudi1
Post by mrdavoudi1 »
Dear Jeff
Hi
I have OXFORD electron mycroscope and need to replace teac fd235hf drive.
I dumping the floppy with DSK2FDI program and it tell me double sided 18 sec/track and 512 byte /sec with 80 track.
But tell me side1 on track0 have 18 bad sector!!
I dump the floppy with hxc software.
When it reached track 0 side 1, one moment the bitrate change from 500 kbit/sec to 1000 kbits/sec and don't say any bad sector.
But in dump file there were no symptom of track 1 head 0  bytes.
Means the software does not read this track.
Can u help me what it mean?
A protected floppy?
How can i dump it ?
With what software or hardware?
In what format I Must export it?(hfe v3)?
This is the  image map of dump file.
If it need i send you the dump file.
I forgot to say that if you look at the number of sectors at the end of the work (photo uploaded ) there is exactly 18 sectors deficit  .The number of track 0 head1 sectors . Without announcing any bad sectors.
Re: Oxford electron microscopy
Only a stream dump analysis can help to answer to all these questions.
