Yamaha A4000 sampler
crueltwist
Post by crueltwist »
Does anyone know if the HxC will work with a Yamaha A4000 sampler?
I couldn't find any info on the compatibility list...
There's a photo of one installed in an ebay listing but the seller claims he hasn't tested it...
https://www.ebay.co.uk/itm/124076255092
Any info would be very much appreciated
Many thanks!
J
Re: Yamaha A4000 sampler
If the jumper is correctly set and the ribbon correctly connected, this should work properly.
